Ed_B
4 years agoNew Contributor
Picture Freezes, goes black, loses sound on wireless boxes
I have 3 wireless boxes, They are never on at the same time. 1 seems to work great all the time, closest to the modem, one works great during the evening but not during the day, this one is only 15' away from the modem with direct site. and one is only watched late night and doesn't work very well at all...
All wireless boxes show all bars for signal strength from the modem...I've had techs out a few times and they've done some things, checked connections etc....problem solved, works for a little bit and then it's back to the same issues....I've done the Ookla speed tests and typical is over 200mbps but sometimes dips to 30mpbs for short periods...
Anyone with any ideas?
- Hello, Have you tried moving the boxes closer to the modem to see if there was any change? Also, how far from the modem is the box that always has issue. Lastly, have you tried swapping out the boxes? -Allan, Cox Support Forums Moderator
