yak
Contributor III
I have Contour 1 and have never seen a frame-by-frame option. only the 2 "slo-speed" options of pausing and then hitting the fast forward button once or twice. Tell us about the frame by frame: what buttons?
CarolLM
6 years agoFormer Moderator
Hi there, to use that feature with a Contour 1 box you'll need to press the "pause" button first, then you'll want to press the white left or right buttons with a black triangle on them to achieve the slo-mo frame-by-frame action. Try that and let us know how that works for you. Thanks, Carol
- yak6 years agoContributor III
CarolLM, thanks. that works perfectly. do you have any other secrets to share?
- 14 days agoMojoGene
- 5 months agolulu007
- 5 years agokristiemom26
- 11 years agoGSETM
