bearone2
4 years agoContributor III
the remote needs to be pointed somewhere near the device you're trying to control!
That's true for infrared but not radio. When I'm working at my table, I can't even see the cable box because not only is my couch in the way but the cable box is nestled within my entertainment console 25 feet away. However, from the table, I can just press the buttons on the remote without even picking it up for it to work. RF is definitely the gooder tech.
- bearone24 years agoContributor III
thank you!
You were right because I originally misread the question. I saw "RF vs. IR" but skimmed over the detail, "input." The Input Select is most likely IR.
- DesertDays4 years agoNew Contributor
True, I was hoping to find an RF model compatible with my box.
- 7 years agoZetram
- 2 years agoEvaluator
- 9 years agoMurgy
- 8 years agoStuckonstupid
