mkampe14
Hello,
I'm glad I am not the only one experiencing this problem with the new router. The WiFi is working on my iPhone and laptop fine, but my Vizio TV cannot connect to WiFi. My network isn't even listed as an option to connect on the TV. I tried calling Cox tech support, but they told me it is a TV issue. It worked fine with the old router, so I don't think it is a problem with the TV. Any input or help from Cox would be appreciated. **I did a factory reset on the TV, no luck. I have reset the modem multiple times with no luck either.**
Thanks, Mara
bearone2
5 years agoContributor III
fwiw, message on samsung tv, "no wi-fi, unable to connect to samsing for update".
i had to use the tv remote for change to wi-fi.
