Rob_Home_TV's avatar
Rob_Home_TV
2 years ago
Can you mix wired and wireless contour boxes?
I would like to add a tv to my existing service. My other boxes are all wired. My new location does not have access to a cable outlet. Can I add a wireless contour box? Chat has led me to believe that I cannot and will need to swap out all my boxes and internet modem/router to wireless only.
Is this correct?
  • Darkatt's avatar
    Darkatt
    Valued Contributor III
    Yes, as long as you are using a Cox Panoramic Modem. Without that modem you won't be able to use a wireless cable box.
  • WiderMouthOpen's avatar
    WiderMouthOpen
    Esteemed Contributor
    I have heard of some people getting the boxes to work wired/ethernet with their own router but YMMV. Some say you need the MoCA adapter inside the gateway for the Video over IP connection while others say you don't need MoCA since it doesn't use a coaxial connection.
    • Darkatt's avatar
      Darkatt
      it MAY work with Ethernet, but I wouldn't place any hard currency on that.....
        WiderMouthOpen
        Either way I don't think that solution will work for OP since if they could run a ethernet wire over to the room then they could just run coaxial and use a normal box. I was just saying it for FYI.
  • @Rob Home TV, I recommend sending us an email with your full name, address, and a brief description of this concern to cox.help@cox.com. -Allan, Cox Support Forums Moderator
