lysbob's avatar
lysbob
3 years ago
modem box
Every morning for the past few days the tv connected to the main modem box is not working. I get a source message and make sure it is connected to cox then I unplug the box for several minutes and reset the wifi. The message on the box says boot and it take over an hour and several attempts with this procedure before the tv connects. The other tvs are able to work but saved recordings are not available until the main box finally connects. I think the main box is going bad.
  • lysbob's avatar
    lysbob
    Thanks for replying. the box is the arris high def DVR receiver. The other boxes are host boxes on the other tvs.
  • bearone2's avatar
    bearone2
    Contributor III
    the set failed, i just went thru this with a house call for the swap, thinking it might be problem with incoming signal.
