It happens the same time in the morning around 10:00 AM but not every day.
Tried switching the HDMI port the cable box plugs into but same issue. This happened with a previous Cox cable box as well.
Even if nobody knows the reason for this that ca be fixed would there be a way to prevent it from happening?
What model TV do you have? Try to disable which version of HDMI-CEC your TV has. That way even if the cable box is turning on, it has no way to turn the TV on.
