Sound cuts out for a couple seconds, picture gets pixel blotches. Problem is now on both of my TV's. It's so bad that I can't watch the program. I reset the box every 3 - 4 days, that helps for an hour or 2. I've been a cox customer for 16 years, up to a year ago my cable was flawless. It seems their total solution is to reset the box. I'm being charged big bucks for inferior service. They know there is a problem but lack the balls to admit it and the intelligence to fix it.
There are no amps or splitters, just poor service that I'm being overcharged for. A technician was here 2 months ago and replaced every connection from the box at the the street to the back of the cable cox. Waste of time.
Assuming you have coaxial, if you have 2 TV sets (2 cable-boxes), you have at least (1) 2-way splitter.
The splitter is on the main line outside the house, separate line run from it to each TV. It was also replaced.
Is there enough slack on the coaxial outside your house to bypass this splitter? I understand the tech...or you...replaced the splitter and it's fine, but splitters, by design, weaken the signal because it splits it.
