For WEEKS now we have had this problem. I have done live chat several times and all anyone does is reset the receiver. I can't see how this could possibly be a receiver issue, this is a broadcasting problem. They wanted to send a tech out, how in the world is a tech going to fix a broadcast problem?
MYTV Channel 1012 , or channel 12 - it doesn't matter what it SAYS is on, what is really being broadcast are programs/network STADIUM
CW Channel 1006 - or channel 06 - it doesn't matter what it SAYS is on, what is REALLY being broadcast are programs/network COMET
it also doesn't matter what day or time, they do not match.
It reads like your local affiliates (channels 6 & 12) have changed networks from, respectively, CW to COMET and MYTV to STADIUM. A couple weeks seems like a long time for this oversight, especially for 2 networks; however, both changes have Cox in common, so...
You might try checking into your Cox account on the net. They usually post channel changes and other info on the sign-in page.
I don't believe OP is questioning an actual channel change but instead what's being displayed in the Program Guide not matching said change.
