Wireless MoCA from box to Pano.
What is wrong with a conventional (coaxial) set-top box?
- hotnguiNew Contributor
I have no coax in the room, hence the need for the wireless. Am just looking for confirmation of whether it should work and if so why it is not working.
Right now the wireless box and Pano are next to each other for testing purposes. Again, works fine until I put the Pano into bridge mode.
Why are you putting the Pano into Bridge Mode? In Bridge Mode, the Pano isn't broadcasting. I don't know how the wireless streamer would still get an updated Guide (hour-by-hour, time, temp, etc) without the Pano broadcasting.
I'll assume...since the Pano is designed to broadcast OTA copy-righted material and providers hate piracy...the wireless streamer will only negotiate with the Pano.
In Bridge Mode, how do you figure 2 devices would communicate?
- bearone2Contributor III
doesn't bridge mode eliminate wifi with pano unit??
LAN WiFi, yes, although its hotspot may still work.
Yes, but my ASUS router has wifi and I set the wireless contour box to use my wifi network. I know that part is working because I can play recorded videos, see the guide, and access the various apps bundled with the box.
Yes, the hotspot works when in bridge mode. I turned it back on to see if that made a difference to my problem per chance but no joy. Still cannot access live TV.
- 6 years agonaturebydawn
- 6 years agoswoopdog
- 3 days agochosmer
