Sort By
How's the soundbar connected?
Were you having problems with the Internet?
- BrianBBNew Contributor
It's: Contour box to TV; TV to SB. Internet works fine.
I don't know why the TV wouldn't consistently power-on unless either the batteries in the remote are low or the infrared sensor is partially obscured.
Good guesses but no obstruction at sensor and batteries are new. Sony thought it might be an issue with the power stripe so I plugged it into the wall-same issues.
- JonathanJFormer Moderator@Leeaskern
You can check the remote battery levels by pressing the Contour button, go to the settings icon and click OK, then go to preferences>remote settings. Also, does the light on the remote turn red when you press a button?
Cox Moderator- BrianBBNew Contributor
Thks..batt is @ 40% but the difficulty in starting occurs with both the Sony remote and the Contour remote. The white light that usually goes on the TV when the power button is pushed on either remote does not go on when the TV won't go on. Prob. not both remotes failing at the same time.
Have you tried repairing the remote to the cable box? This link will provide info https://bit.ly/3oLeNl3. You can also try reprogramming the remote to the TV using this link https://bit.ly/3Fv3MKU.
Cox Moderator
- 8 years agoDr__Robert
- 6 days agoMojoGene
- 10 years agofittobetied
