fetch1944's avatar
fetch1944
4 years ago
Cox contour remote controlling a sony a9g tv
Just purchased a new Sony A9G television and trying to pair it with my Cox Contour remote control.  The remote recognizes that it is a Sony TV, but none of the five digit codes it gives me to try will pair with the TV.  Has anyone successfully programmed their Cox contour remote controller to the Sony A9G?  Does anyone have the code I need to accomplish this?  Any help or suggestions would be appreciated.
    • fetch1944's avatar
      fetch1944
      Allan, thank you for your response.  I have the Contour Voice Remote (XR11) and am following the specific instructions for programming.  It is not successful.  Are you saying that one of Cox's other Contour remotes may work while my XR11 does not?
      • Allan's avatar
        Allan
        @Fetch1944, Our support page lists all of our remotes so that we do not provide the wrong information. -Allan, Cox Support Forums Moderator.
    i don't know if I found any new codes for you.
    10011
    10353
    10810
    10834
    11100
    11317
    11400
    11685
    11786
    11791
    11904
    11925
      fetch1944
      Bruce, four of those codes are new to me and I have not yet tried.  I will give them a go.  Thanks for your help.
