AM2004New Contributor4 years agoConstant Blinking of Live Cable TVWe just got our installation on Tuesday and the tv in the master room blinks in and out ever so often. Any idea what it could be?
4 RepliesReplies sorted by Most LikedSort ByMost LikedOldestNewestMariaLModerator4 years agoHi AM20204, This could be the result of a loose connection. Make sure all cable connections to the cable box are finger tight. Maria Cox Support Forum Moderator AM2004New Contributor to MariaL4 years agoIs not that. All connections are tightly connected. ChrisLFormer Moderator to AM20044 years agoIf the entire picture if flickering in and out that sounds like it might be a problem with the HDMI connection. Do you have a different HDMI cable or port on the TV you can try testing with? -Chrisbearone2Contributor III4 years agohow old/make is the tv?
Related ContentConstant disconnectsConstant Blinking of Live Cable TVConstant Dynamic Range Window violationsBlinking orange/whiteBlinking Yellow & Green Light
Recent DiscussionsTuning Adapter (High-Split) Converter ProblemNo cable serviceUPSETService out 2nd time this weekendRejected
