- JonathanJFormer Moderator@DodgersLakersBruins
Were you having this issue on the app or channel?
Cox Moderator
- TobiasNew Contributor
JonathanJ,
Can U help us out? Not other channel of the 50 or so I receive, other than ESPN Channel 35, has any reception problems. Also, the advertisements on ESPN channel 35 are received perfectly fine, but once the programming returns back to ESPN the audio, and sometimes video, cuts out and is choppy.
What can you do to correct this, as I would like to order additional sports packages, but will not do so if there are any type of cable reception issues?
Best Regards - Tobias
- bearone2Contributor III
what connection speed are you paying for?
- Andrew_WeesContributor III
what does connection speed have to do with tv reception?
Yes, I am, and it is a Cox problem! They may be using a satellite feed to get ESPN channel 35, or their back end systems are under-powered. All I know is they need to fix it!!!
- gsc331New Contributor III
Tobias, i am having same problem in New Orleans area. Got to be Cox problem All other channels are good.
