Rich_R's avatar
Rich_R
Contour Box Broken
My contour box is stuck on the welcome screen and box says "boot". It will attempt to boot for approx10 minutes then shut itself down and try again. I have checked all of the connections, unplugged for 10 seconds and plugged it back it. Problem continues. Help!
  • CurtB's avatar
    CurtB
    Valued Contributor III
    You might need to unplug your receiver for longer than 10 seconds.  The recommended time is 30 seconds.  If that doesn't correct the problem, sign in to your Cox account and try the Cox "Reset My Cable Connection" tool.
  • KevinM2's avatar
    KevinM2
    Hi Rich, are all receivers impacted by this issue? If you have DVR capabilities, then you will need to unplug the host receiver first. This is because the client receiver may need to sync back up to the host receiver. Once the host has finished rebooting, please power-cycle the client receiver. If issues persist, please include a link to this forum thread and email us at cox.help@cox.com. Chances are, we will need to schedule a service appointment. -Kevin M. Cox Support Forum Moderator
