Sort By
- MelissaWagnerNew Contributor
I have this problem in topeka with the local NBC channel. So broken up we usually end up turning it off.
- KevinM2Former Moderator
Are all receivers impacted or only one receiver? Does an error code appear on the screen? Generally, rebooting devices only add temporary relief for signal-related issues. Do you have a splitter in the home? -Kevin M. Cox Support Forum Moderator
- susuknitterNew Contributor
I do have a splitter. One end to the cable box and the other to the internet/phone modem
- AllanModerator@Susuknitter, Is it possible to temporarily bypass the splitter to see if that helps? -Allan, Cox Support Forums Moderator.
