TV pixelation
I've been noticing pixelation on local channels in the last week.  This occurs on both tvs one with mini box the other the big box.  It is an intermittent problem but always seems to happen at the most important time.  St. Charles Parish, Louisiana
  • @Tdbr8de
    Sounds like the signal is intermittent. Have you checked to make sure all the coax ends are hand tight? Also is there a splitter or amp connected to the coax cable?
    Cox Moderator
