Bjo's avatar
Bjo
Remote urc2220r
I have 2 URC2220R remotes that the number pad will not work to change channels and on one of those the up and down will not work either. I have replaced batteries in both
  • Hi Bjo,
    Are you able to turn the TV on and off or access the guide with the remote?
    Maria L.
      • Bjo's avatar
        Bjo
        The guide only shows Program unavailable for every channel
    Two different remotes for two different boxes?  I ask because another OP used two remotes for one box and gradually had problems.  If you have two boxes, try other codes.
    • Bjo's avatar
      Bjo
      Yes 2 different remotes for 2 different boxes/tvs
