I noticed that the time stamp on both of my handsets is incorrect. I set it per the instructions and when I have an incoming call it goes wacky. I is showing 8:38 m when it is 1:30 pm. I have caller Id. How do I fix this? It just started happen about 2 weeks ago. HELP PLEASE
Sounds like a phone issue. What model is it? Also, is the time stamp correct if you log into voice tools?
Also, have you tried resetting your phone modem?
The time on your phone, is set from the phone itself, you will need to look up the instructions for your phone to set the time on it.
gizzmo said:I set it per the instructions
