I have unsuccessfully tried to activate NoMoRoBo and need support. These are the steps performed:
How do I save the setting?
On a related issue, I have seen comments on the NoMORoBo interactions, and its failure to block spam. There are the issues:
*60 . you have to pay for Selective Call Rejection before you can use it. Since it can only store 31 numbers, it is hardly worth the effort.
Selective Call Rejection is actually limited to 25 telephone numbers for Cox Voice. I don't believe there's a fee for using it though, but that may depend on the Cox plan you're on. There is an additional fee for Anonymous Call Rejection.
Is there really a Nomorobo On option in your Cox account? I thought it was just Simultaneous Ring On/Off.
Did you enter your Cox-assigned telephone number into your Nomorobo account?Did you enter your Nomorobo-assigned telephone number into your Cox account?Have you tested your Cox-assigned telephone number from your Nomorobo account?Did you verify if your Cox-assigned telephone number is identified as "Protected" in your Nomorobo account?
I just gave up on Nomorobo and bought a phone with built in call blocking. Just set it to screen all calls, entered the contacts that called me the most so they’ll get through right away, and figured the rest of the real callers will announce their name when prompted. Best investment ever.
