Readable voicemail
I have readable voicemail selected. Only a few of the voicemails show up in readable form. The ones that do appear do so without the phone ever ringing.
  • @George Benthien. There are some limitations to the readable voicemail functionality. If the message left is not in a supported language or is over 90 seconds long, then it will not be transcribed. Also, high amounts of noise or other interference can also cause this issue. -Allan, Cox Support Forums Moderator.
