Daily Dropped Internet Connection
Good morning folks. I have been having an issue with my Cox service for quite sometime. The internet will just "vanish", but the Eth0 & WiFi will continue to work fine. At first, thought it was our router, so purchased a TP-Link AX6000. Still doing the same thing. So, upgraded the router. Cox had mentioned that we would need to upgrade to a DOCSIS v3.1 anyways, so why not. Purchased the CM1000v2 and still having the same results. All the lights stay on and functioning, which is why I originally thought it was the router. Only way to fix it is to power cycle the modem and works fine for a couple days, then same issues all over again.
I had Cox Contractor out last month, and he replaced the line from the Ped (only about 10 yards from our house) to the house. Changed the RG-6 fittings on the line that goes in to the house for approx. 5 feet to the modem, straight from the box outside that wall.
I had to reboot the modem about an hour ago because the internet vanished again. Here are the details of what the modem connection currently looks like while running.
We are on the Cox Gigablast Plan just FYI. Below is the Firmware Info, Connection & Event Logs.
Hardware Version
2.02
Firmware Version
V6.01.07
Cable Modem Serial Number
5UY10CWSxxxxx
CM certificate
Installed
CM MAC
94:a6:7e:0c:xx:xx
Time
Priority
Description
2022-04-23, 08:28:45
Notice (6)
CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
2022-04-23, 08:28:26
Notice (6)
CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
2022-04-23, 08:11:47
Notice (6)
2022-04-23, 08:10:51
Notice (6)
2022-04-23, 07:35:50
Notice (6)
CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
2022-04-23, 07:35:39
Warning (5)
Dynamic Range Window violation
Warning (5)
RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
2022-04-23, 07:35:38
Warning (5)
Warning (5)
Warning (5)
Warning (5)
2022-04-23, 07:35:34
Notice (6)
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
2022-04-23, 07:35:28
Notice (6)
TLV-11 - unrecognized OID;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
Warning (5)
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
Time Not Established
Notice (6)
Honoring MDD; IP provisioning mode = IPv4
Critical (3)
UCD invalid or channel unusable;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2022-04-18, 19:27:10
Critical (3)
No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
2022-04-18, 19:27:09
Critical (3)
2022-04-18, 19:27:07
Critical (3)
Critical (3)
Critical (3)
Critical (3)
Critical (3)
Critical (3)
Critical (3)
2022-03-29, 14:54:04
Critical (3)
Resetting the cable modem due to docsDevResetNow
Critical (3)
Critical (3)
Critical (3)
2022-03-29, 14:50:43
Critical (3)
2022-03-29, 14:42:18
Critical (3)
2022-03-29, 14:42:16
Critical (3)
Critical (3)
Critical (3)
2022-03-29, 14:25:26
Critical (3)
2022-03-29, 14:25:22
Critical (3)
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
2022-03-29, 14:25:05
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=94:a6:7e:0c:xx:xx;CMTS-MAC=00:c1:b1:60:f7:94;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
2022-03-29, 14:25:01
Critical (3)
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
<tabindex=-1>Startup Procedure</tabindex=-1>
Procedure
Status
Comment
Acquire Downstream Channel
903000000 Hz
Locked
Connectivity State
OK
Operational
Boot State
OK
Operational
Security
Enable
BPI+
IP Provisioning Mode
Honor MDD
IPv4 only
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
Channel
Lock Status
Modulation
Channel ID
Frequency
Power
SNR / MER
Unerrored Codewords
Correctable Codewords
Uncorrectable Codewords
Locked
QAM256
21
903000000 Hz
15.2 dBmV
44.9 dB
179623314
0
0
Locked
QAM256
783000000 Hz
14.1 dBmV
44.8 dB
178836118
0
0
Locked
QAM256
789000000 Hz
14.4 dBmV
44.7 dB
178839710
0
0
Locked
QAM256
795000000 Hz
14.4 dBmV
44.8 dB
178843126
0
0
Locked
QAM256
801000000 Hz
14.5 dBmV
44.6 dB
178846617
0
0
Locked
QAM256
807000000 Hz
14.6 dBmV
44.7 dB
178832958
0
0
7
Locked
QAM256
813000000 Hz
14.6 dBmV
44.6 dB
178852888
0
0
8
Locked
QAM256
7
819000000 Hz
14.5 dBmV
44.7 dB
178858281
0
0
9
Locked
QAM256
8
825000000 Hz
14.6 dBmV
44.7 dB
178862070
0
0
10
Locked
QAM256
9
831000000 Hz
14.7 dBmV
44.6 dB
178865680
0
0
11
Locked
QAM256
10
837000000 Hz
14.7 dBmV
44.8 dB
178869501
0
0
12
Locked
QAM256
11
843000000 Hz
14.9 dBmV
44.9 dB
178873239
0
0
13
Locked
QAM256
12
849000000 Hz
15.0 dBmV
44.9 dB
178877025
0
0
14
Locked
QAM256
13
855000000 Hz
14.9 dBmV
44.8 dB
178880782
0
0
15
Locked
QAM256
14
861000000 Hz
14.9 dBmV
44.8 dB
178884915
0
0
16
Locked
QAM256
15
867000000 Hz
14.9 dBmV
44.9 dB
178888532
0
0
17
Locked
QAM256
16
873000000 Hz
14.8 dBmV
44.7 dB
178892258
0
0
18
Locked
QAM256
17
879000000 Hz
14.9 dBmV
44.9 dB
178895685
0
0
19
Locked
QAM256
18
885000000 Hz
15.0 dBmV
44.9 dB
178899440
0
0
20
Locked
QAM256
19
891000000 Hz
15.0 dBmV
45.0 dB
178903158
0
0
21
Locked
QAM256
20
897000000 Hz
15.2 dBmV
44.9 dB
178906915
0
0
22
Locked
QAM256
22
909000000 Hz
15.1 dBmV
44.8 dB
178909785
0
0
23
Locked
QAM256
23
915000000 Hz
15.1 dBmV
45.0 dB
178914503
0
0
24
Locked
QAM256
24
921000000 Hz
15.2 dBmV
44.8 dB
178918163
0
0
25
Locked
QAM256
25
927000000 Hz
15.1 dBmV
44.9 dB
178921913
0
0
26
Locked
QAM256
26
933000000 Hz
15.1 dBmV
44.8 dB
178925705
0
0
27
Locked
QAM256
27
939000000 Hz
15.1 dBmV
44.6 dB
178928403
0
0
28
Locked
QAM256
28
945000000 Hz
15.1 dBmV
44.7 dB
178932006
0
0
29
Locked
QAM256
29
951000000 Hz
15.0 dBmV
44.7 dB
178935911
0
0
30
Locked
QAM256
30
957000000 Hz
15.0 dBmV
44.6 dB
178939168
0
0
31
Locked
QAM256
31
963000000 Hz
14.9 dBmV
44.8 dB
178940446
0
0
32
Locked
QAM256
32
969000000 Hz
14.9 dBmV
44.7 dB
178959633
0
0
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
Channel
Lock Status
Modulation
Channel ID
Frequency
Power
Locked
ATDMA
16900000 Hz
38.0 dBmV
Locked
ATDMA
23500000 Hz
38.0 dBmV
Locked
ATDMA
29900000 Hz
38.0 dBmV
Locked
ATDMA
36300000 Hz
37.8 dBmV
Locked
ATDMA
60000000 Hz
38.0 dBmV
Locked
ATDMA
67000000 Hz
38.0 dBmV
7
Locked
ATDMA
7
74000000 Hz
38.5 dBmV
8
Locked
ATDMA
8
81000000 Hz
39.0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
Channel
Lock Status
Modulation / Profile ID
Channel ID
Frequency
Power
SNR / MER
Active Subcarrier Number Range
Unerrored Codewords
Locked
0, 1, 2, 3
159
300000000 Hz
11.6 dBmV
32.8 dB
1108 ~ 2987
95267045
23910586
0
Not Locked
0
0
0 Hz
9.3 dBmV
0.0 dB
0 ~ 4095
0
0
0
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
Channel
Lock Status
Channel ID
Frequency
Power
Not Locked
Unknown
0
0 Hz
0 dBmV
Not Locked
Unknown
0
0 Hz
0 dBmV
Current System Time: Sat Apr 23 08:41:12 2022
System Up Time: 1:06:13
