Sort By
- JonathanJFormer Moderator@Karen Newhouse
Please check this link and see if it helps www.urcsupport.com/.../.
Cox Moderator - BruceHonored Contributor III
Were the 3 receivers the same makes/models? What's the model number of your current remote? What codes have you tried already?
My bad...OP did provide the remote.
I found a few codes...
Denon
1360
1460
2134
2279
2516
2706
2820
2857
3347
3380- Karen_NewhouseNew Contributor
2134 is the correct number, but the receiver switches to tuner mode when powered on.
To be honest, I'm unsure which "receiver" is new: the cable-box or the Denon.
If the Denon is new, this would be an initial setup and we can work through this. If it's another cable-box, it's usually the authentication within the daisy-chain of HDMI cables causing an issue.
Which receiver is the new device?
- 9 years agoretiredforgood
- 12 years agoPrincess_Grace
- 10 years agogshelly
- 11 years agorossphillips
- 11 years agooffthe_grid
