iambookcase's avatar
iambookcase
4 years ago
Intermittent connection issues, lots of T3 and T4 errors
Hi,
I am experiencing intermittent but frequent connectivity issues.  I was initially told it was my modem. I replaced the modem and still experience the same problems. Now online support says it is the new modem. Can anyone help me figure out what is happening?
The most common errors are
2021-04-09, 22:42:49 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
occurring simultaneously with my disconnects. The modem will reconnect, but it may take seconds or may take minutes.
I have received T4 errors as well.
Additionally, I have received these but I'm not sure which are noteworthy.
2021-04-09, 22:44:31 Warning (5) Dynamic Range Window violation
2021-04-09, 22:44:31 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
2021-04-09, 22:56:23 Notice (6) CM-STATUS message sent. Event Type Code: 16
My modem's connection stats are below.
<tabindex=-1>Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 879000000 Hz Locked
Boot State OK Operational
Security Enable BPI+
IP Provisioning Mode Honor MDD IPv4 only
<tabindex=-1>Downstream Bonded Channels (Partial Service)
Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords
1 Locked QAM256 17 879000000 Hz 1.3 dBmV 32.8 dB 152410479 27103 37
2 Locked QAM256 1 783000000 Hz -2.1 dBmV 41.4 dB 177488079 4234 96
3 Locked QAM256 5 807000000 Hz -0.6 dBmV 41.9 dB 177494658 1533 42
4 Locked QAM256 13 855000000 Hz -0.1 dBmV 41.8 dB 177499025 541 0
5 Locked QAM256 2 789000000 Hz -2.0 dBmV 41.4 dB 151589277 16448 48
6 Locked QAM256 21 903000000 Hz -1.8 dBmV 41.2 dB 174986372 36366 135202
7 Locked QAM256 22 909000000 Hz -2.2 dBmV 41.1 dB 99807023 27506 95373
8 Locked QAM256 23 915000000 Hz -1.1 dBmV 41.5 dB 97831375 26740 115525
9 Locked QAM256 24 921000000 Hz -1.0 dBmV 41.6 dB 26440701 9204 40375
10 Locked QAM256 25 927000000 Hz 0.0 dBmV 42.0 dB 172483912 22587 101254
11 Locked QAM256 26 933000000 Hz 0.3 dBmV 42.0 dB 177526177 45 0
12 Locked QAM256 27 939000000 Hz 0.2 dBmV 41.9 dB 177529946 39 0
13 Locked QAM256 28 945000000 Hz -0.3 dBmV 41.7 dB 177533660 6 0
14 Locked QAM256 29 951000000 Hz -1.2 dBmV 40.9 dB 177537247 5 0
15 Locked QAM256 30 957000000 Hz -2.1 dBmV 41.2 dB 177537829 2278 835
16 Locked QAM256 31 963000000 Hz -1.6 dBmV 41.4 dB 177544446 4 29
17 Locked QAM256 32 969000000 Hz -1.9 dBmV 41.3 dB 177548646 0 0
18 Locked QAM256 3 795000000 Hz -0.4 dBmV 42.1 dB 151706165 1843 35
19 Locked QAM256 4 801000000 Hz 0.7 dBmV 42.3 dB 151711880 3469 28
20 Locked QAM256 6 813000000 Hz -3.1 dBmV 41.0 dB 151719364 3074 34
21 Locked QAM256 7 819000000 Hz -4.9 dBmV 40.1 dB 151728309 1922 91
22 Locked QAM256 8 825000000 Hz -4.1 dBmV 40.5 dB 151735526 2262 5
23 Locked QAM256 9 831000000 Hz -1.9 dBmV 41.6 dB 151741090 3602 67
24 Locked QAM256 10 837000000 Hz 0.6 dBmV 42.4 dB 151752148 773 0
25 Locked QAM256 11 843000000 Hz 1.4 dBmV 42.6 dB 151757109 2818 40
26 Locked QAM256 12 849000000 Hz 1.0 dBmV 42.4 dB 151764289 2039 65
27 Locked QAM256 14 861000000 Hz 0.3 dBmV 36.1 dB 151772927 1516 0
28 Locked QAM256 15 867000000 Hz 0.7 dBmV 37.9 dB 151733909 45250 2635
29 Locked QAM256 16 873000000 Hz 1.6 dBmV 40.9 dB 151788652 354 0
30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
31 Locked QAM256 19 891000000 Hz -1.1 dBmV 36.2 dB 77381000 2193628 2822694
32 Locked QAM256 20 897000000 Hz -2.1 dBmV 41.5 dB 151792950 51 0
<tabindex=-1>Upstream Bonded Channels
1 Locked ATDMA 1 19300000 Hz 51.3 dBmV
2 Locked ATDMA 2 25800000 Hz 56.3 dBmV
3 Locked ATDMA 3 32200000 Hz 58.8 dBmV
4 Locked ATDMA 4 38600000 Hz 58.8 dBmV
5 Not Locked Unknown 0 0 Hz 0.0 dBmV
6 Not Locked Unknown 0 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 Hz 0.0 dBmV
<tabindex=-1>Downstream OFDM Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords
1 Locked 0, 1 159 300000000 Hz 3.1 dBmV 41.8 dB 1108 ~ 2987 126723662 6276709 1792782
2 Not Locked 0 0 0 Hz -1.3 dBmV 0.0 dB 0 ~ 4095 0 0 0
<tabindex=-1>Upstream OFDMA Channels
1 Not Locked Unknown 0 0 Hz 0 dBmV
2 Not Locked Unknown 0 0 Hz 0 dBmV
Current System Time: Fri Apr 09 23:00:37 2021
System Up Time: 1:05:46
1 Locked QAM256 17 879000000 Hz 1.4 dBmV 32.8 dB 76381996 18262 9
2 Locked QAM256 1 783000000 Hz -2.1 dBmV 41.4 dB 101455281 0 0
3 Locked QAM256 5 807000000 Hz -0.6 dBmV 41.8 dB 101459427 0 0
4 Locked QAM256 13 855000000 Hz 0.0 dBmV 42.0 dB 101462805 0 0
5 Locked QAM256 2 789000000 Hz -2.0 dBmV 41.5 dB 75553409 14948 2
6 Locked QAM256 21 903000000 Hz -1.7 dBmV 41.5 dB 99008144 24094 88901
7 Locked QAM256 22 909000000 Hz -2.2 dBmV 41.3 dB 94081764 26967 93758
8 Locked QAM256 23 915000000 Hz -1.1 dBmV 41.6 dB 21880953 10327 45192
9 Locked QAM256 24 921000000 Hz -1.0 dBmV 41.7 dB 20692402 7995 37387
10 Locked QAM256 25 927000000 Hz 0.0 dBmV 41.9 dB 96493512 13887 63116
11 Locked QAM256 26 933000000 Hz 0.3 dBmV 42.0 dB 101488973 0 0
12 Locked QAM256 27 939000000 Hz 0.2 dBmV 41.9 dB 101492770 0 0
13 Locked QAM256 28 945000000 Hz -0.3 dBmV 41.8 dB 101496304 0 0
14 Locked QAM256 29 951000000 Hz -1.3 dBmV 41.0 dB 101500053 0 0
15 Locked QAM256 30 957000000 Hz -2.0 dBmV 41.3 dB 101501707 1524 522
16 Locked QAM256 31 963000000 Hz -1.6 dBmV 41.3 dB 101507320 4 29
17 Locked QAM256 32 969000000 Hz -1.9 dBmV 41.2 dB 101511290 0 0
18 Locked QAM256 3 795000000 Hz -0.4 dBmV 42.1 dB 75670764 8 35
19 Locked QAM256 4 801000000 Hz 0.7 dBmV 42.3 dB 75678145 7 28
20 Locked QAM256 6 813000000 Hz -3.1 dBmV 39.5 dB 75685161 16 17
21 Locked QAM256 7 819000000 Hz -4.9 dBmV 40.0 dB 75693094 15 24
22 Locked QAM256 8 825000000 Hz -4.2 dBmV 40.7 dB 75700587 0 0
23 Locked QAM256 9 831000000 Hz -1.9 dBmV 41.7 dB 75707428 0 0
24 Locked QAM256 10 837000000 Hz 0.6 dBmV 42.5 dB 75715605 0 0
25 Locked QAM256 11 843000000 Hz 1.4 dBmV 42.5 dB 75722848 0 0
26 Locked QAM256 12 849000000 Hz 0.9 dBmV 42.4 dB 75729094 0 0
27 Locked QAM256 14 861000000 Hz 0.3 dBmV 36.1 dB 75737008 0 0
28 Locked QAM256 15 867000000 Hz 0.8 dBmV 35.5 dB 75731887 12394 5
29 Locked QAM256 16 873000000 Hz 1.6 dBmV 40.6 dB 75751735 0 0
31 Locked QAM256 19 891000000 Hz -1.0 dBmV 27.9 dB 10237441 14286 16223
32 Locked QAM256 20 897000000 Hz -2.1 dBmV 41.3 dB 75756078 0 0
2 Locked ATDMA 2 25800000 Hz 55.8 dBmV
1 Locked 0, 1 159 300000000 Hz 3.3 dBmV 40.8 dB 1108 ~ 2987 72680458 823183 16756
  • BenS1's avatar
    BenS1
    Hi @ Iambookcase,
    I know it is frustrating to have unresolved issues with your modem. There are a lot of timeouts on your modem. Are there any splitters or amplifiers that are connected to the coaxial that is screwed into the back of your modem? If so can you please bypass any splitters/amplifiers and plug it directly into the wall from the modem?
    Ben S.
    • iambookcase's avatar
      iambookcase
      I think a tech might have put in a splitter in the box outside on my house, because I live in a condo association with several units closeby. I don't have any splitters on my end though.
      • JonathanJ's avatar
        JonathanJ
        @iambookcase
        Since the splitter may be outside I suggest scheduling a technician out. Please email your full name, address, and a link to this thread to cox.help@cox.com.
        Cox Moderator
