Sort By
I'd be leery of one entity promising something and to also be the same entity "proving" you're getting the something. Make sense? If Cox promises 300 Mbps, for example, why allow Cox to verify you're getting the 300 Mbps? I'd use a 3rd-party...and 4th, 5th, 6th...to prove the promise.
Overall, no speedtest site should be as invasive as Ookla appears to be. It's just a speedtest...not a commitment. Perhaps it's just the link you're using. Can you use ookla.com?
- bearone2Contributor III
i've been using the free ookla for years.
fwiw: ookla lets you check other servers in the area, where you're checking cox speeds!!
