rtucker88's avatar
rtucker88
4 years ago
Connection Drops with Logs/Stats
Hi all,
I'm having issues with my connection dropping over the past couple of weeks. It's gotten progressively more frequent. I'm using a Netgear CM1200 modem. Here's some of the stats and some of the logs I captured shortly after a disconnect.
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 795000000 Hz Locked
Boot State OK Operational
Security Enabled BPI+
IP Provisioning Mode Honor MDD honorMdd(4)
Downstream Bonded Channels (Partial Service)
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 21 795000000 Hz -0.8 dBmV 39.8 dB 855 3652
2 Locked QAM256 1 675000000 Hz -3.3 dBmV 38.8 dB 198188 508950
3 Locked QAM256 2 681000000 Hz -2.6 dBmV 39.4 dB 33939 29240
4 Locked QAM256 3 687000000 Hz -3.6 dBmV 39.2 dB 24622 20271
5 Locked QAM256 4 693000000 Hz -3.2 dBmV 39.5 dB 429 43
6 Locked QAM256 5 699000000 Hz -3.5 dBmV 39 dB 15637 37903
7 Locked QAM256 6 705000000 Hz -3.2 dBmV 38.9 dB 10768 19238
8 Locked QAM256 7 711000000 Hz -2.7 dBmV 39 dB 3219 9506
9 Locked QAM256 8 717000000 Hz -2.4 dBmV 39 dB 200 41
10 Locked QAM256 9 723000000 Hz -2.1 dBmV 39.4 dB 196 45
11 Locked QAM256 10 729000000 Hz -2.3 dBmV 26.8 dB 99983535 262997546
12 Not Locked Unknown 11 735000000 Hz 0.0 dBmV 0.0 dB 0 0
13 Not Locked Unknown 12 741000000 Hz 0.0 dBmV 0.0 dB 0 0
14 Not Locked Unknown 13 747000000 Hz 0.0 dBmV 0.0 dB 0 0
15 Not Locked Unknown 14 753000000 Hz 0.0 dBmV 0.0 dB 0 0
16 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
17 Not Locked Unknown 16 765000000 Hz 0.0 dBmV 0.0 dB 0 0
18 Locked QAM256 17 771000000 Hz -1.2 dBmV 39.8 dB 166 1
19 Locked QAM256 18 777000000 Hz -1.6 dBmV 39.7 dB 92125 206684
20 Locked QAM256 19 783000000 Hz -0.7 dBmV 39.7 dB 33068 40063
21 Locked QAM256 20 789000000 Hz -1.3 dBmV 39.5 dB 2671 12268
22 Locked QAM256 22 801000000 Hz -0.6 dBmV 39.8 dB 175 0
23 Locked QAM256 23 807000000 Hz 0.4 dBmV 40.4 dB 137 0
24 Locked QAM256 24 813000000 Hz 0.3 dBmV 40.5 dB 135 0
25 Locked QAM256 25 819000000 Hz -0.3 dBmV 40.5 dB 12904 27734
26 Locked QAM256 26 825000000 Hz 0.1 dBmV 40.5 dB 21412 72461
27 Locked QAM256 27 831000000 Hz -0.2 dBmV 40.2 dB 92 0
28 Locked QAM256 28 837000000 Hz -0.3 dBmV 40.3 dB 91205 233534
29 Locked QAM256 29 843000000 Hz 0.3 dBmV 40.5 dB 129221 423099
30 Locked QAM256 30 849000000 Hz -0.4 dBmV 40.2 dB 610 16
31 Locked QAM256 31 855000000 Hz 0.7 dBmV 39.3 dB 120 0
32 Locked QAM256 32 861000000 Hz 1.1 dBmV 34.8 dB 97 0
Upstream Bonded Channels
1 Locked ATDMA 1 5120 Ksym/sec 17400000 Hz 58.8 dBmV
2 Locked ATDMA 2 5120 Ksym/sec 23900000 Hz 54.3 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 30300000 Hz 54.3 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 36700000 Hz 54.3 dBmV
5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
Downstream OFDM Channels
Channel Lock
Status Modulation /
Profile ID Channel
ID Frequency Power SNR /
MER Active Subcarrier
Number Range Unerrored
Codewords Correctable
Codewords Uncorrectable
Codewords
1 Locked 0 ,1 ,2 ,3 159 288000000 Hz -0.9 dBmV 42.3 dB 1108 ~ 2987 542399010 435355120 567
2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1 Not Locked 0 0 0 Hz 0 dBmV
Time Priority Description
Sun Oct 25 16:36:19 2020 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:36:19 2020 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:36:18 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:36:13 2020 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 10 15; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:36:13 2020 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:36:11 2020 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 5 6 7 10 15 16 19 25 26; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:51 2020 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 10; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:46 2020 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:39 2020 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 10 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:38 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:33 2020 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 5 6 7 10 15 16 19 25 26; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:31 2020 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:29 2020 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:27 2020 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 5 6 7 10 15 16 19 25 26; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:27 2020 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:19 2020 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 10 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:18 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:15 2020 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 5 6 7 10 15 16 19 25 26; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:12 2020 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:12 2020 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:12 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:01 2020 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 10 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:35:01 2020 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 5 6 7 10 15 16 19 25 26; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:59 2020 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:56 2020 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 10; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:55 2020 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 5 6 7 10 15 16 19 25 26; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:50 2020 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 10 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:50 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:39 2020 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 10 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:38 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:37 2020 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 10 15; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:33 2020 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 10; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:32 2020 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:32 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:31 2020 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 10 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:31 2020 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:30 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:25 2020 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:11 2020 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 10 15 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
Sun Oct 25 16:34:10 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:af:e3:c8;CMTS-MAC=00:d6:fe:e6:d1:d2;CM-QOS=1.1;CM-VER=3.1;
It generally seems like 1-3 channels have a lower SNR with an accompanying high number of uncorrectables.
  • ChrisL's avatar
    ChrisL
    Looking from this end you have a group of channels not bonding suggesting that a technician may need to come out and troubleshoot further. Feel free to email us at cox.help@cox.com and we can assist with that further.
    -Chris
