- jdcomeauxNew Contributor
Also the cox technician could only get 300 mbs on her own cell phone while connecting to my wifi. seems very strange. She also could not explain what is causing any issues. When she spoke with her supervisor he mentioned that it was my equipment. So I had her ask him When you try a brand new laptop or the iphone 11 or even her phone an they all getting around 300 mbs what could cause all the same sppeds he had no answer.
- bearone2Contributor III
the tech is using cox test equipment.
try another test site like this + check other test sites within the site, cox usually come in lower for me.
- BigLagBatesNew Contributor
Also that only shows you the connection to that one server. Cox doesn’t let you know that that connection then needs to be sent out to other servers to tech final server for whatever it is you are tying to do on the internet. The amount of jitter/ latency and routes it then takes is largely because of their poor infrastructure and old coax lines. Garbage the price of gold.
I have tried multiple speedtest mostly to fiber connection and still only get at max 300 mbs.
- cr0shNew Contributor
How many channels on your cable modem up/down do you have - give us the make/model # of your cable modem, and we can find that out.
If you don't have the right number of channels, your speed will be limited to an upper amount. I had to upgrade my modem that way, since the modem I was using (an older model I had for a while) didn't have the right number of channels. When I upgraded to one with the proper number - speed increased.
Note: I have been with Cox broadband since the "Cox@Home" days and the big grey foot warmer modems (2000-01 time frame) - and also on the internet since 1993 - and prior to that on BBS's even longer back to 1987...
- GregP1ModeratorWhat are the results when testing with a wired connection?
GregP
Cox Forums moderator
