Sort By
What version of DOCSIS is your modem?
- edceteraNew Contributor II
3.0
Netgear CG3000Dv2: DOCSIS 3.0, 8 × 4, Preferred 100, 100 Mbps / 10 Mbps
You said there isn't the slightest hint of any increase. What are you comparing this to...perception? Could you hardwired directly to the modem and perform a speed test? You may be getting 50 Mbps.
What's the make/model of your router?
My problem is resolved, I had 2 wireless routers attached and 1 was off, I turned it on and all was fixed, I then turned if off again and it stayed fixed.
