mikerbagley
5 years agoNew Contributor
Will Moca work or whats my options?
Hello
I currently have Cox internet with speeds of 300+, I see they have gigablast now for the same price I am paying for cable internet. I have their panoramic wifi modem and I am running moca due to where my office is upstairs its the best option I had found at the time. I go straight out their modem the cable then in my office from the wall to a MOTOROLA MOCA Adapter for Ethernet Over Coax, 1,000 Mbps Bonded 2.0 MoCA (Model MM1000) then to my PC. I can't find anywhere is Cox gigablast modem they rent you allows moca as my current one does, or will I need to buy another adapter or will it not work at all and I should just stick with what I have otherwise won't have internet in my office.
