Hello - I've been having upload speed issues the last couple weeks (barely getting 1Mbps - occasionally shoots up to 7Mbps) Do these power levels look normal? There isn't much online, but the little I did find said these should be around the 45 dBmV range. I tried to reach out to chat support, but they had no idea what these power levels were. I've included my Downstream power as well.
I have a Netgear CM1000 > Google WiFi > 8-Port Gb Cisco Switch > Hardwired PC (has not changed - used to be able to get 35Mbps speeds - and download speeds are 300-400Mbps still)
No changes to modem location or wiring.
Upstream Bonded Channels |
Channel |
Lock Status |
Modulation |
Channel ID |
Frequency |
Power |
1 |
Locked |
ATDMA |
1 |
19600000 Hz |
32.8 dBmV |
2 |
Locked |
ATDMA |
2 |
26000000 Hz |
32.8 dBmV |
3 |
Locked |
ATDMA |
3 |
32400000 Hz |
33.3 dBmV |
4 |
Locked |
ATDMA |
4 |
38800000 Hz |
33.3 dBmV |
5 |
Not Locked |
Unknown |
0 |
0 Hz |
0.0 dBmV |
6 |
Not Locked |
Unknown |
0 |
0 Hz |
0.0 dBmV |
7 |
Not Locked |
Unknown |
0 |
0 Hz |
0.0 dBmV |
8 |
Not Locked |
Unknown |
0 |
0 Hz |
0.0 dBmV |
Downstream Bonded Channels |
Channel |
Lock Status |
Modulation |
Channel ID |
Frequency |
Power |
SNR / MER |
Unerrored Codewords |
Correctable Codewords |
Uncorrectable Codewords |
1 |
Locked |
QAM256 |
10 |
837000000 Hz |
6.4 dBmV |
39.3 dB |
60990119 |
610 |
0 |
2 |
Locked |
QAM256 |
1 |
783000000 Hz |
6.9 dBmV |
39.6 dB |
60723216 |
278 |
0 |
3 |
Locked |
QAM256 |
2 |
789000000 Hz |
6.7 dBmV |
39.5 dB |
60726630 |
435 |
0 |
4 |
Locked |
QAM256 |
3 |
795000000 Hz |
7.0 dBmV |
39.6 dB |
60730522 |
392 |
0 |
5 |
Locked |
QAM256 |
4 |
801000000 Hz |
7.6 dBmV |
39.8 dB |
60734617 |
270 |
0 |
6 |
Locked |
QAM256 |
9 |
831000000 Hz |
6.8 dBmV |
39.5 dB |
60737128 |
809 |
0 |
7 |
Locked |
QAM256 |
41 |
405000000 Hz |
8.0 dBmV |
39.6 dB |
57494873 |
519 |
0 |
8 |
Locked |
QAM256 |
11 |
843000000 Hz |
6.3 dBmV |
39.3 dB |
60746035 |
1396 |
0 |
9 |
Locked |
QAM256 |
12 |
849000000 Hz |
6.2 dBmV |
39.3 dB |
60750664 |
1857 |
0 |
10 |
Locked |
QAM256 |
17 |
879000000 Hz |
4.8 dBmV |
38.8 dB |
60753528 |
2564 |
0 |
11 |
Locked |
QAM256 |
18 |
885000000 Hz |
5.1 dBmV |
38.9 dB |
60757397 |
1910 |
0 |
12 |
Locked |
QAM256 |
19 |
891000000 Hz |
5.3 dBmV |
38.9 dB |
60759465 |
1936 |
0 |
13 |
Locked |
QAM256 |
20 |
897000000 Hz |
5.4 dBmV |
39.1 dB |
60765635 |
1785 |
0 |
14 |
Locked |
QAM256 |
21 |
903000000 Hz |
5.3 dBmV |
39.1 dB |
60769141 |
2051 |
0 |
15 |
Locked |
QAM256 |
22 |
909000000 Hz |
5.0 dBmV |
38.9 dB |
60772008 |
2273 |
0 |
16 |
Locked |
QAM256 |
25 |
927000000 Hz |
4.9 dBmV |
38.9 dB |
60775753 |
2097 |
0 |
17 |
Locked |
QAM256 |
26 |
933000000 Hz |
5.2 dBmV |
39.2 dB |
60780752 |
1636 |
0 |
18 |
Locked |
QAM256 |
27 |
939000000 Hz |
5.6 dBmV |
39.3 dB |
60784588 |
1205 |
0 |
19 |
Locked |
QAM256 |
28 |
945000000 Hz |
6.1 dBmV |
39.4 dB |
60788579 |
792 |
0 |
20 |
Locked |
QAM256 |
29 |
951000000 Hz |
6.4 dBmV |
39.6 dB |
60793065 |
457 |
0 |
21 |
Locked |
QAM256 |
30 |
957000000 Hz |
6.5 dBmV |
39.7 dB |
60796843 |
265 |
0 |
22 |
Locked |
QAM256 |
33 |
357000000 Hz |
7.9 dBmV |
39.3 dB |
60800795 |
0 |
0 |
23 |
Locked |
QAM256 |
34 |
363000000 Hz |
7.9 dBmV |
39.7 dB |
60804448 |
0 |
0 |
24 |
Locked |
QAM256 |
35 |
369000000 Hz |
7.7 dBmV |
39.5 dB |
60807674 |
0 |
0 |
25 |
Locked |
QAM256 |
36 |
375000000 Hz |
7.3 dBmV |
39.3 dB |
60811836 |
0 |
0 |
26 |
Locked |
QAM256 |
37 |
381000000 Hz |
7.3 dBmV |
39.4 dB |
60815815 |
0 |
0 |
27 |
Locked |
QAM256 |
38 |
387000000 Hz |
7.3 dBmV |
39.4 dB |
60819168 |
0 |
0 |
28 |
Locked |
QAM256 |
42 |
411000000 Hz |
8.5 dBmV |
39.7 dB |
60822502 |
0 |
0 |
29 |
Locked |
QAM256 |
43 |
417000000 Hz |
8.8 dBmV |
39.8 dB |
60826515 |
0 |
0 |
30 |
Locked |
QAM256 |
44 |
423000000 Hz |
9.0 dBmV |
39.9 dB |
60830271 |
0 |
0 |
31 |
Locked |
QAM256 |
45 |
429000000 Hz |
9.4 dBmV |
40.0 dB |
60831200 |
0 |
0 |
32 |
Locked |
QAM256 |
46 |
435000000 Hz |
9.5 dBmV |
40.0 dB |
60830796 |
0 |
0 |
