can I add other streaming apps to the contour streaming device?
or, is the device a closed system like the original APPLE TV device?
The link doesn't work. I would like to see CBS All Access on my tv using Contour. I can see Amazon Prime but that seems to be the only streaming app I can use.
Could you confirm a Cox Panoramic gateway is technically required for the streamer player to work? Documentation says yes, but reports from the field say it's possible with 3rd party router.
For example...
One contributor, RobIT, reports the Wireless 4K Stream Player works with his router (Linksys Velop).forums.cox.com/.../105107forums.cox.com/.../105025
