ChandlerAZ85224's avatar
ChandlerAZ85224
Dropping Internet Intermittently. Modem poor signal. Poor downstream power level and high error.
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables
1 Locked QAM 256 1 783000000 Hz -4.5 dBmV 40.9 dB 6 0
2 Locked QAM 256 2 789000000 Hz -5.0 dBmV 40.3 dB 3 0
3 Locked QAM 256 3 795000000 Hz -5.0 dBmV 40.9 dB 6 0
4 Locked QAM 256 4 801000000 Hz -5.0 dBmV 40.9 dB 11 0
5 Locked QAM 256 5 807000000 Hz -5.2 dBmV 40.9 dB 0 0
6 Locked QAM 256 6 813000000 Hz -6.0 dBmV 40.3 dB 0 0
7 Locked QAM 256 7 819000000 Hz -6.7 dBmV 40.3 dB 0 0
8 Locked QAM 256 8 825000000 Hz -7.0 dBmV 38.6 dB 12 0
9 Locked QAM 256 9 831000000 Hz -6.7 dBmV 40.3 dB 14 0
10 Locked QAM 256 10 837000000 Hz -6.5 dBmV 40.3 dB 0 0
11 Locked QAM 256 11 843000000 Hz -7.0 dBmV 38.9 dB 0 0
12 Locked QAM 256 12 849000000 Hz -8.0 dBmV 38.9 dB 0 0
13 Locked QAM 256 13 855000000 Hz -8.2 dBmV 38.6 dB 3 0
14 Locked QAM 256 14 861000000 Hz -7.9 dBmV 38.6 dB 5 0
15 Locked QAM 256 15 867000000 Hz -7.4 dBmV 38.9 dB 8 0
16 Locked QAM 256 16 873000000 Hz -7.7 dBmV 38.9 dB 4 0
17 Locked QAM 256 17 879000000 Hz -8.7 dBmV 38.6 dB 5 0
18 Locked QAM 256 18 885000000 Hz -9.5 dBmV 38.9 dB 7 0
19 Locked QAM 256 19 891000000 Hz -9.2 dBmV 38.6 dB 13 0
20 Locked QAM 256 20 897000000 Hz -8.5 dBmV 38.6 dB 7 0
21 Locked QAM 256 21 903000000 Hz -8.7 dBmV 38.6 dB 16816 504479
22 Locked QAM 256 22 909000000 Hz -9.2 dBmV 37.6 dB 58876 1505682
23 Locked QAM 256 23 915000000 Hz -10.0 dBmV 37.6 dB 80601 1971591
24 Locked QAM 256 24 921000000 Hz -10.2 dBmV 38.6 dB 77232 1924747
25 Locked QAM 256 25 927000000 Hz -9.2 dBmV 38.2 dB 396 12459
26 Locked QAM 256 26 933000000 Hz -8.9 dBmV 38.6 dB 0 0
27 Locked QAM 256 27 939000000 Hz -9.4 dBmV 37.9 dB 0 0
28 Locked QAM 256 28 945000000 Hz -9.9 dBmV 38.2 dB 0 0
29 Locked QAM 256 29 951000000 Hz -10.0 dBmV 37.9 dB 0 0
30 Locked QAM 256 30 957000000 Hz -9.7 dBmV 37.3 dB 0 0
31 Locked QAM 256 31 963000000 Hz -9.7 dBmV 37.6 dB 0
0
32 Locked QAM 256 32 969000000 Hz -9.7 dBmV 37.3 dB 4 0
Upstream Bonded Channels
1 Locked ATDMA 1 5120 Ksym/sec 16900000 Hz 35.3 dBmV
2 Locked ATDMA 2 5120 Ksym/sec 23500000 Hz 35.3 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 29900000 Hz 35.3 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 36300000 Hz 35.3 dBmV
5 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
6 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
7 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
8 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
  • WiderMouthOpen's avatar
    WiderMouthOpen
    Looks like ingress in the 900Mhz range, probably from cellular. Have you bypassed all the spitters in the house?
  • Hello ChandlerAZ85224,
    I am so sorry to hear that you are experiencing intermittent interruptions in your service. That would be very frustrating. We want you to have service that you can rely on. When experiencing signal issues, the first step should be to check the connections within the home to make sure that nothing has changed that could interfere with the signal getting to the modem/gateway. When you have a chance, can you go through the steps below to ensure everything between the connections is secured?
    Check the connections to ensure they are all secured and the cables are undamaged.
    If you are using a splitter, bypass it by connecting the coaxial cable directly from the wall outlet to the modem.
    If you are using an amplifier in the home, check that it is secured and the light is lit to the AC adapter.
    Make a wired connection by plugging an Ethernet cable directly from the modem/Gateway to the device.
    Reboot the modem/Gateway by unplugging the power for 30 seconds and reconnecting it.
    If the issue continues after these steps, can you email my team at cox.help@cox.com with your name, address, and a link to this thread?
    Tiffany R.
    • ChandlerAZ85224's avatar
      ChandlerAZ85224
      I did the checks and still have the issue.  Looks to be getting worse:
      1 Locked QAM 256 1 783000000 Hz -4.2 dBmV 40.3 dB 975 4925
      2 Locked QAM 256 2 789000000 Hz -4.7 dBmV 40.3 dB 732 4041
      3 Locked QAM 256 3 795000000 Hz -4.9 dBmV 40.9 dB 403 2998
      4 Locked QAM 256 4 801000000 Hz -4.9 dBmV 40.3 dB 642 3042
      5 Locked QAM 256 5 807000000 Hz -5.0 dBmV 40.3 dB 470 4029
      6 Locked QAM 256 6 813000000 Hz -5.7 dBmV 40.3 dB 1005 4859
      7 Locked QAM 256 7 819000000 Hz -6.5 dBmV 40.3 dB 825 5198
      8 Locked QAM 256 8 825000000 Hz -6.9 dBmV 38.6 dB 687 5934
      9 Locked QAM 256 9 831000000 Hz -6.5 dBmV 40.3 dB 721 5377
      10 Locked QAM 256 10 837000000 Hz -6.2 dBmV 40.3 dB 721 6255
      11 Locked QAM 256 11 843000000 Hz -6.9 dBmV 38.9 dB 958 3931
      12 Locked QAM 256 12 849000000 Hz -7.7 dBmV 38.9 dB 864 4261
      13 Locked QAM 256 13 855000000 Hz -8.0 dBmV 38.6 dB 868 7262
      14 Locked QAM 256 14 861000000 Hz -7.5 dBmV 38.9 dB 819 5962
      15 Locked QAM 256 15 867000000 Hz -7.0 dBmV 38.9 dB 1414 6509
      16 Locked QAM 256 16 873000000 Hz -7.4 dBmV 38.9 dB 769 7215
      17 Locked QAM 256 17 879000000 Hz -8.4 dBmV 38.6 dB 1785 5248
      18 Locked QAM 256 18 885000000 Hz -9.2 dBmV 38.9 dB 1156 5863
      19 Locked QAM 256 19 891000000 Hz -8.7 dBmV 38.6 dB 1186 7018
      20 Locked QAM 256 20 897000000 Hz -8.2 dBmV 38.9 dB 2170 7264
      21 Locked QAM 256 21 903000000 Hz -8.2 dBmV 38.6 dB 19354 628457
      22 Locked QAM 256 22 909000000 Hz -8.9 dBmV 34.2 dB 33287 938983
      23 Locked QAM 256 23 915000000 Hz -9.7 dBmV 37.6 dB 286213 7015372
      24 Locked QAM 256 24 921000000 Hz -9.7 dBmV 38.9 dB 283020 6706063
      25 Locked QAM 256 25 927000000 Hz -8.7 dBmV 38.2 dB 1002 30639
      26 Locked QAM 256 26 933000000 Hz -8.5 dBmV 38.6 dB 173 2115
      27 Locked QAM 256 27 939000000 Hz -9.0 dBmV 37.9 dB 103 1427
      28 Locked QAM 256 28 945000000 Hz -9.5 dBmV 38.2 dB 165 1481
      29 Locked QAM 256 29 951000000 Hz -9.7 dBmV 37.9 dB 131 1968
      30 Locked QAM 256 30 957000000 Hz -9.5 dBmV 37.3 dB 84 2124
      31 Locked QAM 256 31 963000000 Hz -9.4 dBmV 37.6 dB 133 1489
      32 Locked QAM 256 32 969000000 Hz -9.5 dBmV 37.3 dB 132 1467
  • Coutured's avatar
    Coutured
    I have the same issue with my connection being normal and then random going out completely or just poor. I’ve talked to the support on here but it’s still been a week. Working from home this week has been a challenge at times.
      WiderMouthOpen
      You might want to start your own post with your signal levels and issue details.
