Millie2010's avatar
Millie2010
what are and how do I use the, "Hot Keys" on my home phone? Like *73, to Block my number Etc...?
What are, and how do I use the, "Hot Keys" on my home phone? Like *73, to Block my number from showing Etc...?
  • Hi Millie2010,
    If you have call forwarding activated, then using *73 turns off the Call Forwarding Service. Using Caller ID Per Call Blocking is *67. With Caller ID Per Call Blocking, your name and number are blocked from being displayed to others on a per-call basis. You must press *67 before each call you place, otherwise; your name and phone number is released to the person receiving your call. I recommend testing this before making the call to someone you don't want to see your number. Calls to 911, 800, and 900 numbers cannot be blocked using *67.
    https://www.cox.com/residential/support/phone/articles/features-and-guides.html
    https://www.cox.com/residential/education-center/phone/managing-calls.html
    Above are a couple links to our website with helpful information about managing calls and phone features. I hope this information helps you.
