Bradz
7 years agoNew Contributor
Using Logitech universal remote with Arris XG1v3 Contour2 box
Hi - I have a home theater system requiring 4 remotes, and I'd like to run it from a universal remote. I bought a Logitech "Harmony Smart Control" with a programmable hub. It will work with everything in the system except the Arris XG1v3 Contour2 box. I did some research on the box and XR11 voice remote, and it looks like this remote communicates with the box via RF. The Harmony communicates with the hub in RF, but the hub talks to the components in IR. Is there a way to configure the Arris to use IR instead?
Thanks
- Hi Bradz,
The Contour 2 XR11 remote can function in both RF and IR mode. Contour 2 receivers use the same IR codes as the Comcast Xfinity receivers. When setting up the Logitech Harmony remote/hub, look for Cisco XG1 or Cisco XG1A device codes.
