GearsInLa's avatar
GearsInLa
Upload Speed Issues - Unicast Maintenance T3 errors
I've been having serious problems with upload speed since April (2MB or less on a 10 MB plan with packet loss).  Download speed doesn't appear to be affected.
We have had 5-6 visits from technicians and all cabling and equipment has been replaced including the service line to the house but the problem is still occuring. I've checked my modem event log and I am getting numerous "Started Unicast Maintenance Ranging - No Response received - T3 time-out" errors every day.
Is anyone else having long-term issues with upload speed or getting these errors?
  • ChrisL's avatar
    ChrisL
    @GearsInLa
    It looks like you did have a maintenance ticket and that has since been resolved. Can you try signing into your http://www.cox.com account and testing your speeds there to see if there are still any issues?
  • GearsInLa's avatar
    GearsInLa
    Just ran test on cox site - 106 download, 2.6 upload
    Check Speed
    Cox Market:
    Baton Rouge
    Change Market
    What do these measurements mean?
       Your Results
    Start
     Cox
    Net
    Download
    Speed
    Upload
    Speed
    Latency
    Your IP
    Address
    Cox Market
    Thu Dec 1 5:51 PM Yes 107 Mbps 3 Mbps 14 millisec 68.226.229.93 Baton Rouge
  • ChrisL's avatar
    ChrisL
    @GearsInLa
    Looking from this end I'm seeing some packet loss to the modem and it's also reporting possible power issues. Do you have the modem plugged into a power strip with a lot of other devices? It might be worth trying to connect it to a different power source and see if that helps.
    GearsInLa
    Bought a battery backup power strip and plugged in only the modem and router.  Also swapped modem this morning for new Netgear CM600.  Still same issue with upload speed.
  • ChrisL's avatar
    ChrisL
    @GearsInLa
    From this end everything looks better up to the modem. You can try testing again with a direct connection and see if that makes a difference. If not, it may be time to see about having a technician come out and troubleshoot further.
  • fcontreras's avatar
    fcontreras
    Any luck getting cox to fix your issue? Ive also been having upload issues for quite some time now.
