chinmaya
7 years agoNew Contributor
Upload power levels jumping and modem resets
This is the current power levels for upload channels
Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
1 | Locked | ATDMA | 4 | 5120 Ksym/sec | 36300000 Hz | 42.7 dBmV |
2 | Locked | TDMA and ATDMA | 1 | 2560 Ksym/sec | 18400000 Hz | 44.2 dBmV |
3 | Locked | ATDMA | 2 | 5120 Ksym/sec | 23300000 Hz | 40.7 dBmV |
4 | Locked | ATDMA | 3 | 5120 Ksym/sec | 29800000 Hz | 45.2 dBmV |
Periodically it jumps to >54dMv and I get an error from the modem that's this
Time | Priority | Description |
Tue Nov 15 15:15:53 2016 | Warning (5) | Dynamic Range Window violation |
This has been happening alot now and it's quite frustrating. Any help will be appreciated. We plug the modem directly to the line on the wall with a cable and don't have any splitters in between.
Update: Contacted support via chat and they said there were too many power adjustments being done by the modem and they think the fault is the modem. Also here's the info I have right now on the downstream channels:
Downstream Bonded Channels | ||||||||
Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Corrected | Uncorrectables |
1 | Locked | QAM256 | 62 | 975000000 Hz | 2.7 dBmV | 38.2 dB | 32 | 0 |
2 | Locked | QAM256 | 57 | 945000000 Hz | 2.7 dBmV | 38.2 dB | 0 | 0 |
3 | Locked | QAM256 | 58 | 951000000 Hz | 2.5 dBmV | 38.2 dB | 0 | 0 |
4 | Locked | QAM256 | 59 | 957000000 Hz | 3.2 dBmV | 38.6 dB | 1 | 0 |
5 | Locked | QAM256 | 60 | 963000000 Hz | 2.8 dBmV | 38.2 dB | 4 | 0 |
6 | Locked | QAM256 | 61 | 969000000 Hz | 3.0 dBmV | 38.3 dB | 23 | 0 |
7 | Locked | QAM256 | 63 | 981000000 Hz | 2.0 dBmV | 37.9 dB | 30 | 0 |
8 | Locked | QAM256 | 64 | 987000000 Hz | 1.9 dBmV | 37.8 dB | 86 | 400 |
