mybigbrain's avatar
mybigbrain
split signal help
I want to watch my cable programs on a second tv. My box is DCX3400 . What do I need to split that signal and will I still get
HD on the second tv?
  • AllenP's avatar
    AllenP
    Valued Contributor
    Do you want to watch the same channel on both TV's or two different channels?  The DCX3400 only outputs one channel at a time so, if you want to watch different channels @wees41 is correct ... you will need a minibox or another digital STB.
    If you want to watch the same channel on both TV's (or 1 TV at a time), you may be able to split the output.  How are you connecting the DCX3400 to your TV, hdmi?  Here is an example of an hdmi splitter.
