Speed Check Results Slower If Not Logged in To My Account
I went to the Cox Website and ran the speed test before signing in. It is the speed test choice listed just to the left of the sign-in fields and displays a big speed dial while testing. Over the course of an hour of tests the best result was 15 mbps down, 6 mbps up and latency of 117. The worst was 4 down, 4 up, and 1231 latency. After signing in to my account, Cox used a different speed check program. It has an itzy-bitzy speed dial and displays the results in a different format and with 2 decimal points. Its best result was 64.02 down, 5.77 up, and latency of 10 My plan is the 50 mbps plan so getting 64 down was quite a shock and totally unbelievable as it was taking 20 seconds for new pages to load on the Cox site. The wireless adapter speed is 130 mbps. The higher test results are what showed up on the speed check history for my account, thus Cox has no clue how bad things are, and in fact can brag that my service is exceeding what is advertised.
My other laptop gives consistent results whether logged in or not:: usually around 24 down, 6 up, and latency of 10. It is still slow but not as bad as the first one mentioned above. Its wireless adapter is 54 mbps.
After resetting the Cox modem/router the results were the same.
Previous tests using a wired ethernet connection gave the same results as the wireless tests.
Has anyone else had similar results?
