kathann
7 years agoNew Contributor
scientific atlanta 4240 HDC aspect ratio problems
The Scientific Atlanta 4240HDC will not change the picture size of either of my SD tvs when I change the aspect ratio options in settings. and the HD zoom button does not result in a change in the picture size. There are lines across top and bottom of the picture. I thought it was my Magnavox SD tv, but then I got ahold of a SD Sony and the same results. The Cox minibox will expand the picture, but I need the composite and s-video connectors, for use with my vcr, which the minibox does not have. please a solution???? I enquired back in November and never received a response.
the tv picture will not change even if the vcr is not hooked up.
any live chat or call to Cox has not resulted in any solution.
thanks,
