8 years agoHonored Contributor III
Rovi Power-On Channel
The power-on channel stopped working for my cable box (CSH4642).
When I turn on my TV and cable box, the power-on channel is now the standard-definition channel of C-SPAN. I've confirmed my power-on channel in the settings, which is correct, and reset my cable box. However, it still defaults to C-SPAN SD, channel 41.
Also, whenever my cable box re-synchronizes during the day, the channel changes to C-SPAN SD.
What happened?
- Hi Bruce,
Due to overnight maintenance, the servers that process cable receiver transactions are backed up. A signal to reinitialize the receiver is pending. I'll be able to tell when the signal processes, and we can check the power-on channel after the reset is confirmed. I apologize for the delay!
