JonathanZ1
10 years agoNew Contributor
Outgoing smtp login problem
On my Windows Phone 8, every time I open my email I get a notification that says "Cox account info is incorrect, update your account info for smtp.cox.net and tap save." I read on another forum how to fix it and id did not work. I put my info in the notification and it rejects it. I went into my settings and changed it from smtp.east.cox.net to just smtp.cox.net. I use my full email xxx@cox.net as the login and my password, doesn't work. I also use my email without the @cox.net and it doesn't work. Yet every time I send an email, it sends. I have to hit the back button to get out of the notification and to my email screen, but after a month this has become very annoying.
I do not have this problem on my outlook 2007 on my desktop (windows 8.1), but on my windows 8.1 tablet in thunderbird, I have this problem but it won't send at all. The thunderbird problem isn't a very big deal for me but I would like my phone not to ask me my outgoing password every time I open email because it thinks it is incorrect.
First the smtp.cox.net vs smtp.cox.net shouldn't matter. Both should work.
Second I would check your account and see if you maybe have a extra smtp entry that has incorrect info. That might explain why it sends but gives you the error both.
Third you just want to use your username in general but why are you even using username and password for smtp (outbound) mail? Are you sending from outside cox's network? Try no authentication on outbound on port 25. See if that works.
