Phone_Disconnec
8 years agoNew Contributor III
Magnavox DVR MDR513H/F7 will not work with Cox mini digital box
I installed the Cox mini digital box a couple of weeks ago as part of the all digital conversion. I have been trying off an on every since to connect my Magnavox DVR without any success. I am pretty sure I have it connected correctly as I am able to connect a Sony DVD/VHS combo and it works fine (other than the poor recording and audio issues the mini box are causing). When I connect the DVR, with the DVR and TV channel set to 3 as instructed, I am getting no playback picture nor can I play a movie. I can see the countdown change on the DVR display but there is nothing shown on the TV. I cannot access any of the DVR functions using the DVR remote - it is as if it is non-existent even though it appears the cable input is working since I am able to use TV remote and change channels using mini box remote. Just cannot get anything from the DVR. I cannot afford to pay Cox the $20+ more a month they want for their DVR and service so I would greatly appreciate any guidance that could be provided. I am currently using the Sony DVD/VHS combo but in addition to the VHS recording issues mentioned above, I cannot play any movies since adding the mini box. They freeze over and over and drop audio. I am at my wits end and have too much money invested in this DVR to throw more money to Cox. If I am forced to use Cox DVR service then I may as well go DIrectTV. If I could I would love to cut the cable but internal antenna will not work (per antenna.org it is a line of site issue where I live) and landlord refuses to let me have an outdoor antenna installed on duplex.
Thanks in advance for the help!
AllenP said:
OK I am stuck again. The chart from the 513H manual shows the DVR Audio In connections going to Audio/Video Out connections on a digital box. I do not have those connections on the mini box. TV does not have HDMI connection. Could you please explain in simple language how to do the yellow-white-red connections? I cannot find anything on Cox site that shows how to and the chart I was sent in a earlier posting was simple in/out cable connections with no mention of yellow-white-red. The chart was for connecting a VCR/DVD recorder and I did not realize it was different for a DVR. Is there a chart that shows proper connections for DVR? Again, thank you so much for the help.Phone Disconnect said:
The TV works fine with the DVR connected or without it connected, I just do not get playback or have any DVR functions working from remote. Will report back once I try the alternate connection. Thanks all for helping me!If you are saying the minibox plays thru the TV regardless if the DVR is connected or not, that's consistent with the manual. The DVR will pass through the minibox signal to the coax output but not play anything from the hard drive or DVD drive. Thing is, the 557 manual says the same thing. If you were using the antenna output to play recorded items in the past, all I can say is maybe the manual is wrong. Worth a try using composite (Y/R/W) output.
