riteshraja's avatar
riteshraja
Lots of internet connection issues past 2 weeks - Rancho Santa Margarita area
Seeing lots of intermittent issues where the internet stops working for 1-2 minutes every 5 minutes or so during what I assume are peak hours - 5PM - 8PM. I have the message in the modem log which immediately precedes the issue -
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ca:08:72:ec:8b;CMTS-MAC=00:1d:a2:e7:d9:89;CM-QOS=1.1;CM-VER=3.0;
Any suggestions on a fix? I have Preferred package so speed and connectivity are crucial since I work out of the house.
  • riteshraja's avatar
    riteshraja
    SB6183
    Status
    The statuses listed show the connection state of the cable modem. They are used by your service provider to evaluate the operation of the cable modem.
    Startup Procedure
    Procedure Status Comment
    Acquire Downstream Channel   Locked
    Boot State OK Operational
    Configuration File OK
    Security Enabled BPI+
    Downstream Bonded Channels
    Channel Lock Status Modulation Channel ID Frequency Power SNR Corrected Uncorrectables
    1 Locked QAM256 28 801000000 Hz -2.0 dBmV 39.0 dB 3967 5218
    2 Locked QAM256 25 783000000 Hz -2.4 dBmV 39.0 dB 3923 4289
    3 Locked QAM256 26 789000000 Hz -2.4 dBmV 38.9 dB 3847 4935
    4 Locked QAM256 27 795000000 Hz -2.5 dBmV 38.6 dB 4141 5087
    5 Locked QAM256 29 807000000 Hz -1.4 dBmV 39.5 dB 4087 5847
    6 Locked QAM256 30 813000000 Hz -1.4 dBmV 39.6 dB 4196 5819
    7 Locked QAM256 31 819000000 Hz -1.1 dBmV 39.9 dB 4303 6107
    8 Locked QAM256 32 825000000 Hz -1.1 dBmV 39.9 dB 3881 6540
    9 Locked QAM256 41 879000000 Hz -2.0 dBmV 39.8 dB 3395 6943
    10 Locked QAM256 42 885000000 Hz -2.1 dBmV 39.8 dB 3012 6160
    11 Locked QAM256 43 891000000 Hz -2.3 dBmV 39.8 dB 3209 6012
    12 Locked QAM256 44 897000000 Hz -2.4 dBmV 39.8 dB 2963 5241
    13 Locked QAM256 45 903000000 Hz -2.7 dBmV 39.8 dB 3056 4434
    14 Locked QAM256 46 909000000 Hz -2.4 dBmV 39.8 dB 2698 4087
    15 Locked QAM256 47 915000000 Hz -2.4 dBmV 39.8 dB 2704 4124
    16 Locked QAM256 48 921000000 Hz -2.3 dBmV 39.9 dB 2849 3088
    Upstream Bonded Channels
    1 Locked ATDMA 4 5120 Ksym/sec 36800000 Hz 41.9 dBmV
    2 Locked TDMA and ATDMA 1 2560 Ksym/sec 17600000 Hz 37.6 dBmV
    3 Locked ATDMA 2 5120 Ksym/sec 24000000 Hz 40.5 dBmV
    4 Locked ATDMA 3 5120 Ksym/sec 30400000 Hz 40.2 dBmV
    Current System Time: Tue Jul 26 18:01:15 2016
    riteshraja
    Information
    Standard Specification Compliant DOCSIS 3.0
    Hardware Version 1
    Software Version D30CM-OSPREY-1.5.0.1-GA-01-NOSH
    Cable Modem MAC Address 6c:ca:08:72:ec:8b
  • ChrisL's avatar
    ChrisL
    @riteshraja
    From this end it looks like the upstream signal is intermittently experiencing problems. Are there any cable splitters you can try bypassing to see if that helps?
    riteshraja
    I have zero splits. A cord cutter - no cable in the house - only internet.
  • ChrisL's avatar
    ChrisL
    @riteshraja
    You could see if there are any other cable outlets you can try connecting the modem to. If that doesn't work it may be time to see about having a technician come out and troubleshoot further.
