Intermittent loss of connection
We have had intermittent loss of signal for a couple of years. We've had techs come out and say the problem is with our modem which we just upgraded again, this time to an SB6183.
Here is the status:
The statuses listed show the connection state of the cable modem. They are used by your service provider to evaluate the operation of the cable modem. Sometimes if we unplug it and plug it back in, it works. Sometimes it doesn't. We have had techs out so many times who tell us there is not a problem, but there is a problem.
Startup Procedure | ||
Procedure | Status | Comment |
Acquire Downstream Channel | Locked | |
Connectivity State | OK | Operational |
Boot State | OK | Operational |
Configuration File | OK | |
Security | Enabled | BPI+ |
DOCSIS Network Access Enabled | Allowed |
Downstream Bonded Channels | ||||||||
Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Corrected | Uncorrectables |
1 | Locked | QAM256 | 99 | 795000000 Hz | -6.7 dBmV | 41.1 dB | 2597 | 1371 |
2 | Locked | QAM256 | 97 | 783000000 Hz | -6.7 dBmV | 41.0 dB | 2597 | 1322 |
3 | Locked | QAM256 | 98 | 789000000 Hz | -6.7 dBmV | 41.0 dB | 2771 | 1384 |
4 | Locked | QAM256 | 100 | 801000000 Hz | -6.8 dBmV | 40.9 dB | 2613 | 1530 |
5 | Locked | QAM256 | 101 | 807000000 Hz | -6.8 dBmV | 40.9 dB | 2728 | 1426 |
6 | Locked | QAM256 | 102 | 813000000 Hz | -6.8 dBmV | 40.9 dB | 2664 | 1500 |
7 | Locked | QAM256 | 103 | 819000000 Hz | -6.8 dBmV | 40.8 dB | 2659 | 1511 |
8 | Locked | QAM256 | 104 | 825000000 Hz | -7.2 dBmV | 40.5 dB | 2766 | 1768 |
9 | Locked | QAM256 | 113 | 879000000 Hz | -7.3 dBmV | 40.3 dB | 2639 | 1391 |
10 | Locked | QAM256 | 114 | 885000000 Hz | -7.5 dBmV | 40.3 dB | 2713 | 1367 |
11 | Locked | QAM256 | 115 | 891000000 Hz | -8.1 dBmV | 40.2 dB | 2735 | 1480 |
12 | Locked | QAM256 | 116 | 897000000 Hz | -8.3 dBmV | 40.2 dB | 2711 | 1501 |
13 | Locked | QAM256 | 117 | 903000000 Hz | -8.8 dBmV | 40.1 dB | 2804 | 1438 |
14 | Locked | QAM256 | 118 | 909000000 Hz | -8.9 dBmV | 40.0 dB | 2806 | 1482 |
15 | Locked | QAM256 | 119 | 915000000 Hz | -9.1 dBmV | 39.9 dB | 2772 | 1345 |
16 | Locked | QAM256 | 120 | 921000000 Hz | -9.4 dBmV | 39.8 dB | 2760 | 1411 |
Upstream Bonded Channels | ||||||
Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
1 | Locked | TDMA and ATDMA | 1 | 2560 Ksym/sec | 17600000 Hz | 50.5 dBmV |
2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 25800000 Hz | 50.5 dBmV |
3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 32200000 Hz | 51.5 dBmV |
4 | Locked | ATDMA | 4 | 5120 Ksym/sec | 38600000 Hz | 54.0 dBmV |
Current System Time: Sat Jul 23 07:44:43 2016
Here red is the log since unplugging it.
The table below contains the log of events that the SB6183 has detected. This log can be important to the service provider to help diagnose and correct problems, if any should occur.
Time | Priority | Description |
Fri Jul 22 19:53:52 2016 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=74:ea:e8:ee:38:b1;CMTS-MAC=00:13:5f:06:e1:63;CM-QOS=1.1;CM-VER=3.0; |
Fri Jul 22 19:53:13 2016 | Warning (5) | Dynamic Range Window violation |
Fri Jul 22 19:53:09 2016 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=74:ea:e8:ee:38:b1;CMTS-MAC=00:13:5f:06:e1:63;CM-QOS=1.1;CM-VER=3.0; |
Time Not Established | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=74:ea:e8:ee:38:b1;CMTS-MAC=00:13:5f:06:e1:63;CM-QOS=1.0;CM-VER=3.0; |
Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
Time Not Established | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:ee:38:b1;CMTS-MAC=00:13:5f:06:e1:63;CM-QOS=1.0;CM-VER=3.0; |
Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=74:ea:e8:ee:38:b1;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=74:ea:e8:ee:38:b1;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
Time Not Established | Notice (6) | Rng Rsp Abort Status - Reinitialize MAC... |
Time Not Established | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:ee:38:b1;CMTS-MAC=00:13:5f:06:e1:63;CM-QOS=1.0;CM-VER=3.0; |
Time Not Established | Critical (3) | No Ranging Response received - T3 time-out |
Time Not Established | Notice (6) | T1 No Ucd Timeout - Reinitialize MAC... |
Time Not Established | Critical (3) | No UCDs Received - Timeout;;CM-MAC=74:ea:e8:ee:38:b1;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
Time Not Established | Warning (5) | Lost MDD Timeout;CM-MAC=74:ea:e8:ee:38:b1;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
