Contour 2 Record 6 (Arris XG1v3) box with Harmony (universal) remote
We just had this box installed on Saturday and love it and the whole home service. However, I've been unable to get my Harmony hub to control it. No command issued from the remote/hub is being executed. The Arris box sits in the same rack with 4 other devices (Denon AV Receiver, Sony Blu-Ray player, Roku, and Apple TV) that the Harmony controls without issue.
So I have questions:
- If the Arris is paired with the Cox remote by RF, does the Arris box turn off the IR receiver?
- Does anyone else have this working with both a universal (IR) remote AND the Cox remote in RF mode?
- Does anyone know if there is a trick to getting a universal remote to work well with the Arris XG1? (Such as modifying repeat or using codes for a different device?)
Thanks for any help!
The information that pairing the RF remote disables the IR port is on the Contour 2 boxes is incorrect.
I currently have 3 Contour 2 host boxes and 1 Contour 2 client box which all have the supplied remote paired for RF but still work just fine with my universal remotes via IR. I don't have a Harmony remote, but use URC MX-850 remotes and one MX-980. The key is just finding the right set of IR codes for your Harmony.
Try setting up your Harmony as though you have Comcast Xfinity. The Contour 2 boxes are really just rebranded Xfinity technology and they use the same hardware so the Comcast Xfinity IR codes should work.
