Baseball_Nut's avatar
Baseball_Nut
Contour 2 Mini Box Voice Remote
Just noticed the voice remote on my Contour 2 mini box does not work. When I speak, the blue LED light comes on but I receive a "press and hold to try again" indication. I release the voice button at which time the LED turns red. All other functions work properly. Have not changed any settings on TV/box/remote. Main box works fine. Any suggestions?
  • @Baseballfan001
    First, try unplugging the power cord of the cable box for 10 seconds and see if that helps.
  • JonathanJ's avatar
    JonathanJ
    @Baseballfan001
  • Baseball_Nut's avatar
    Baseball_Nut
    As many years as we've had Cox, I should have tried this first: always unplug then replug. Voice remote now works fine!! Would have thought more problems would have shown up but just the voice remote. Thanks for the help!!
    JonathanJ
    @Baseballfan001
    Most welcome please let us know if you have further issues.
