Constant Drops - Connection Issues
I have been experiencing serious connection issues for the past 4 days. The internet connection is down more often than it is up. I called tech support and was told there were numerous errors coming from the node that typically indicate a problem at the node. A tech dispatch was scheduled. The soonest available was 3 days later. I called back a day later to see if an earlier appointment was available and was told my internet was down due to a hub outage (an entirely different reason). I then got online and opened a chat with another technical support person and was given yet a third excuse for my service being out. Three different contact attempts and three different reasons for my service being out.
I have connected the modem directly to the computer to eliminate any WIFI issues. This has not changed the issue. I have connected the modem directly to the demarcation point at my utility box. This has not changed the issue.
I am attaching my signal levels in the hopes that something can be done. If needed, I can post the error logs as well.
Downstream | Bonding Channel Value | ||||||||
Channel ID | 70 | 65 | 66 | 67 | 68 | 69 | 71 | 72 | |
Frequency | 939000000 Hz | 909000000 Hz | 915000000 Hz | 921000000 Hz | 927000000 Hz | 933000000 Hz | 945000000 Hz | 951000000 Hz | |
Signal to Noise Ratio | 38 dB | 39 dB | 39 dB | 39 dB | 39 dB | 38 dB | 38 dB | 38 dB | |
Downstream Modulation | QAM256 | QAM256 | QAM256 | QAM256 | QAM256 | QAM256 | QAM256 | QAM256 | |
Power Level
4 dBmV | 6 dBmV | 6 dBmV | 6 dBmV | 5 dBmV | 5 dBmV | 5 dBmV | 6 dBmV |
Upstream | Bonding Channel Value | |||
Channel ID | 3 | 1 | 2 | 4 |
Frequency | 38600000 Hz | 25800000 Hz | 32200000 Hz | 17600000 Hz |
Ranging Service ID | 3 | 3 | 3 | 3 |
Symbol Rate | 5.120 Msym/sec | 5.120 Msym/sec | 5.120 Msym/sec | 2.560 Msym/sec |
Power Level | 41 dBmV | 41 dBmV | 41 dBmV | 41 dBmV |
Upstream Modulation | [3] 16QAM [3] 64QAM |
[3] QPSK [2] 16QAM [3] 64QAM |
Ranging Status | Success | Success | Success | Success |
Signal Stats (Codewords) | Bonding Channel Value | |||||||
Total Unerrored Codewords | 358324808 | 358333027 | 358341213 | 358349310 | 358313149 | 358314331 | 358315414 | 358316313 |
Total Correctable Codewords | 12 | 1 | 0 | 1 | 41 | 16 | 16 | 18 |
Total Uncorrectable Codewords | 1559 | 1433 | 1428 | 1517 | 1488 | 1404 | 1399 | 1557 |
