volksworker's avatar
volksworker
CISCO 8642 HDC will not control volume with HDMI - FACT
The cisco 8642hdc has no way to control volume with hdmi installed through the box........except to go into settings and changed to variable every time you turn the box on....and then it doesnt give you a display bar on screen.......also new versions dont have a 110 volt outlet................There is a previous thread locked from 2 years ago where cox says they are working on it. These new boxes are junk..........3 trips to the cox store and Im going back again. Guys there are nice but dont know anything about their equipment or do and play dumb. Get this fixed or get a box that works!
  • AllenP's avatar
    AllenP
    Valued Contributor
    Since I started using digital audio, toslink or hdmi, I've never used a STB to control audio.  I use the receiving device, either an audio/video receiver in my main setup or the TV itself, to control volume. It's a digital signal on the hdmi cable, volume is basically an analog function. I let the AVR decode the digital codec then apply volume control on output. I don't think what you are seeing is anything new with the 8642hdc.
    Can't speak to the AC outlet, I have a DVR which uses an external power supply, hence no 110 outlet.
  • volksworker's avatar
    volksworker
    Well that's nice but I'm using a vintage McIntosh stereo system having owned and found all surround systems to be not worth it............the Scientific Atlanta box previously used ( 3 weeks ago) controlled the volume perfectly with HDMI..........blowing your "volume is basically an analog function" theory................"decode the digital codec" ???? Are you for real ? .........I'm an engineer. Do you mean run the audio through the TV in real English for people who read this with the same problem? The point is I don't want to control volume through the TV or I wouldn't have posted this. I use the box to turn on the amplifier and pre amp....................."I let the AVR decode the digital codec then apply volume control on output." ..... LOL BOTTOM LINE .........no regular volume control on these boxes if you use hdmi.....no 110 outlet on newest 8642hdc....cox employees should know that and be able to inform customers
  • AllenP's avatar
    AllenP
    Valued Contributor
    Nice you have a vintage McIntosh stereo, which must have stereo analog inputs. How are you getting from hdmi to analog for input to the Mc? Are you using the stereo output of the 8642? You seam to be omitting things in your post.
