change_wifi_pin's avatar
change_wifi_pin
changing wifi pin
where can I change my wifi pin on line?
  • AllenP's avatar
    AllenP
    Valued Contributor
    Are you talking about the WPS pin or the WiFi password (PSK, pre-sharred key)? You can't change either online, you must log into your gateway or router. Specific instructions depend on the model gateway or router you have. This article may help. If you need more help, please post make/model of your device.
