thecat18's avatar
thecat18
6 tuner contour home dvr
Just wondering, how many tv's can I have the 6 tuner contour home dvr on, I would like it on 3 tv's.
  • SharielH said:
    Hey thecat18, I am not showing an email. Can you resend it?
    Ok I sent it again I hope I did it right I am at work & had to do it on my phone. Thanks, it's from bbarletta@cox.net. I just need to setup an appt. to fix our cable ASAP. Also see if the contour2 boxes would work if our cable is fixed again. Thanks.
  • Hi tecat18,
    For every 1 Contour 2 DVR, you can network up to 3 clients to access the DVR network. Each client utilizes one of the 6 available tuners of the DVR receiver.
  • thecat18's avatar
    thecat18
    Ok so can I record up to 6 things on the main dvr unit.
  • thecat18,
    One stand alone Contour 2 6-tuner DVR can record 6 simultaneous shows. If you're watching TV on the DVR, then you're taking up one of the tuners, and can record 5 shows at once.
    Customers may subscribe up to twelve Contour 2 devices per home. Up to three host and up to three clients per host.
    You said you have 3 TVs. You can't record 6 programs at once if you have two of the tuners used by the two Client receivers. You can choose to have multiple record 6 contour 2 receivers in the home (up to three 6 tuner DVR Host receivers). If you don't see yourself needing that many tuners (18) at once, then you may consider one Host 6 tuner DVR, and 2 client receivers. This setup would only take up 2 tuners from the Host DVR, and allow you the other 4 tuners to record (if you're not using 1 tuner watching TV from the Host DVR).
  • thecat18's avatar
    thecat18
    Ok, now we have 3 separate dvr's on 3 tvs, which of the new contour would be best & for the best price if for example during primetime I record 2 shows at once on all 3 dvr's. Also will the pixels tiling & other dvr issues, like playing back a recording when it's still recording & the status bar not showing up right away & not stopping fast forwarding for a while, when it's still recording, will those issues be better, I do reboot our dvrs & it seems to get worse at 1st, for ex. I was recording a show last night & noticed half way through it wasn't recording, the channel wasn't available until I turned the dvr off & on again. We have had technicians recently fix issues in the cables, but it seems these problems cont. at various times.
  • MarkM1's avatar
    MarkM1
    thecat18
    It would seem that you would benefit from having two host 6 DVR boxes & one client box. You would be able to nine programs at once and still watch TV on the three boxes. The Contour 2 service requires that we certify your home before installation. This should fix any issues that you are having with tiling on your TV. We hope this information was helpful.
  • thecat18's avatar
    thecat18
    MarkM1 said:
    thecat18
    Ok what does certify our home before installation mean? I have been waiting to empty my dvrs now before I upgrade, we still have shows on there. If I get the 2 main boxes & 1 client box what are price difference between the 3 standalone cisco explorer dvr's from a couple yrs. ago I have now?
  • Hi Thecat18,
    The the monthly rental fee for a Standard Digital Receiver, Advanced HD receiver, or DVR is the same, regardless of the IPG (video platform). All Rovi, Contour, and Contour 2 boxes are $8.50 a month.
  • thecat18's avatar
    thecat18
    Ok so can I order that many  boxes that way from the website.  Also mentioned was this.
    What does cerify my home mean?
  • thecat18,
    Scheduling a professional installation by a technician will certify the wiring and networking to provide you the best service outcome.
  • Jerry's avatar
    Jerry
    Contributor II
    Who's on first, what's on second, and I don't know's on third.
